Skip to content
GitLab
Explore
Sign in
Stefan Schindler
encrypted_filesystem_storage
Compare revisions
4039ab2e9b584342aa5530f9de1bdc05fde588b5 to f334a39606aa537cf9eeb0d8458668c91a12da6f
Commits on Source (2)
Make the locking configurable with a feature flag
· 3b75792a
Stefan Schindler
authored
May 27, 2023
3b75792a
Expose SecureFileHandler and flush() on drop
· f334a396
Stefan Schindler
authored
May 29, 2023
f334a396
Hide whitespace changes
Inline
Side-by-side
Cargo.toml
View file @
f334a396
[workspace]
members
"multi_key_manager"
"aead_vfs"
"aead_vfs"
"cli"
[workspace.package]
aead_vfs/Cargo.toml
View file @
f334a396
@@ -10,6 +10,10 @@ license.workspace = true
# See more keys and their definitions at https://doc.rust-lang.org/cargo/reference/manifest.html
[features]
default
"fs_locks"
fs_locks
"multi_key_manager/fs_locks"
[dependencies]
multi_key_manager
path
"../multi_key_manager"
features
"with_nonce"
aead_vfs/src/errors.rs
View file @
f334a396
@@ -12,6 +12,8 @@ pub enum CvfsErrors {
/// Std::io::Error
GeneralIO
String
/// Std::io::Error with a reason
ContextIO
'static
str
String
/// A constant time error occured in the `ring` crate
GeneralRingEncryptionError
MutexUnlockError
String
@@ -22,6 +24,16 @@ pub enum CvfsErrors {
RmpDecode
String
pub
fn
specify_io_error
O
r
Result
O
std
io
Error
reason
'static
str
CvfsResult
O
r
.map_err
e
CvfsErrors
ContextIO
reason
format!
"{e:?}"
pub
fn
specify_kme_error
O
r
Result
O
multi_key_manager
errors
KeyManagementError
reason
'static
str
CvfsResult
O
r
.map_err
e
CvfsErrors
ContextIO
reason
format!
"{e:?}"
impl
From
std
io
Error
for
CvfsErrors
fn
from
e
std
io
Error
Self
CvfsErrors
GeneralIO
format!
"{e:?}"
aead_vfs/src/lib.rs
View file @
f334a396
@@ -9,13 +9,14 @@ use std::{
pub
mod
errors
use
errors
CvfsErrors
CvfsResult
use
errors
specify_io_error
specify_kme_error
CvfsErrors
CvfsResult
mod
aead
use
aead
decrypt_file_buffered
encrypt_file_buffered
pub
mod
metadata
use
metadata
FileInfo
FileTag
Metadata
mod
secure_file
use
secure_file
ActiveFile
SecureFileHandler
use
secure_file
ActiveFile
pub
use
secure_file
SecureFileHandler
const
SUPERBLOCK_PATH
str
"encfsstorage.superblock"
const
BLOCK_PATH
str
"blocks/"
@@ -26,7 +27,7 @@ pub fn open_dir<P: AsRef<Path>>(
directory_path
P
Result
CryptoVFS
CvfsErrors
let
directory_path
directory_path
.as_ref
.to_owned
create_dir_all
directory_path
specify_io_error
create_dir_all
directory_path
"unable to create_dir_all"
let
keys_path
path_extend
directory_path
SUPERBLOCK_PATH
if
keys_path
.is_dir
return
Err
CvfsErrors
GeneralIO
format!
@@ -41,16 +42,26 @@ pub fn open_dir<P: AsRef<Path>>(
metadata_path
.display
let
mut
metadata_file
open_rwlocked
metadata_path
let
mut
metadata_file
specify_io_error
open_rwlocked
metadata_path
#[cfg(feature
"fs_locks"
"unable to lock the metadata"
#[cfg(not(feature
"fs_locks"
"unable to open the metadata"
let
blocks_path
path_extend
directory_path
BLOCK_PATH
create_dir_all
blocks_path
specify_io_error
create_dir_all
blocks_path
"unable to create blocks_path"
let
mut
keys
if
keys_path
.is_file
let
keys
if
keys_path
.is_file
LiveKeys
read_from_disk
decryption_input
keys_path
else
LiveKeys
generate_new
decryption_input
keys_path
let
mut
keys
specify_kme_error
keys
"unable to read or generate master key"
let
metadata
if
metadata_file
.empty
Metadata
empty
aead_vfs/src/secure_file.rs
View file @
f334a396
@@ -248,6 +248,17 @@ impl Read for SecureFileHandler {
.map_err
e
std
io
Error
new
std
io
ErrorKind
Other
format!
"{e:?}"
impl
Drop
for
SecureFileHandler
fn
drop
mut
self
if
let
Err
error
self
.try_flush
if
panicking
eprintln!
"SecureFileHandler::drop() -> {error:?}"
else
panic!
fn
stdout_flush
std
io
Result
std
io
stdout
.flush
multi_key_manager/Cargo.toml
View file @
f334a396
@@ -12,8 +12,9 @@ license.workspace = true
[features]
default
default
"fs_locks"
with_nonce
fs_locks
"fs4"
[dependencies]
argon2
version
"0.4.1"
features
"rand"
@@ -26,7 +27,7 @@ rmp-serde = "1.1.1"
serde
version
"1.0.152"
features
"derive"
# lock the keys file while it is in use
fs4
"0.6.3"
fs4
version
"0.6.3"
features
"sync"
optional
true
#[target.'cfg(unix)'.dependencies]
#libc = "0.2.139"
multi_key_manager/src/file.rs
View file @
f334a396
use
core
ops
Deref
DerefMut
#[cfg(feature
"fs_locks"
use
fs4
FileExt
use
std
fs
File
as
StdFile
OpenOptions
@@ -20,7 +21,10 @@ pub fn open_rwlocked<P: AsRef<Path>>(path: P) -> IoResult<File> {
//println!("File::open_rwlocked(... {:?}) at {}",path.file_name(),file.stream_position()?);
file
.rewind
file
.lock_exclusive
#[cfg(feature
"fs_locks"
file
.lock_exclusive
Ok
File
file
